DESPIECE REDUCTORA SPICER T18
Mensaje por mariano salvay » Mar May 26, 2009 8:56 pm
1. Companion Flange
3. Emergency Brake Drum
3. Emergency Brake Shoes
4. Brake Operating Lever
5. Bearing Cap Oil Seal *
6. Brake Operating Lever Stud
7. Rear Bearing Cap
8. Rear Bearing Cap Shim Set *
9. Bolt
10. Lockwasher
11. Bolt
12. Transfer Case Rear Cover
13. Gasket, rear cover *
14. Intermediate Shaft Lock Plate
15. Transfer Case
16. Shift Rod
17. Poppet Plug
18. Poppet Spring *
19. Poppet Ball *
20. Shift Rod Interlock
21. Gasket, bearing cap
22. Cap, front bearing
23. Breather
24. Seal, oil, shift rail *
25. End Yoke
26. Gasket, oil seal *
27. Bolt
28. Lockwasher
29. Shift Rod
30. Front Wheel Drive Shift Fork
31. Underdrive and Direct Shift Fork
32. Filler Plug
33. Gear, input shaft
34. Washer, input gear
35. Washer, thrust *
36. Gear, intermediate
37. Ring, retaining / snap, front output bearing *
38. Bearing, front output shaft
39. Nut, companion flange
40. Washer, plain
41. Output Clutch Shaft
42. Output Clutch Shaft Gear
43. Ring, snap / retaining, front output shaft
44. Washer, thrust *
45. Output Shaft Gear
46. Gear, output shaft, sliding
47. Bushing, output shaft pilot *
48. Shaft, output
49. Bearing, tapered roller, rear output *
50. Cup, tapered roller, rear output *
51. Gear, speedometer drive
52. Bearings, needle roller *
53. Spacer, bearing *
54. Shaft, intermediate idler *
55. Plug, drain
56. Gasket, bottom cover *
57. Nut, input shaft
58. Cover, bottom (pan)
59. Speedometer Driven Gear Sleeve
60. Speedometer Driven Gear (15-t)
61. Speedometer Driven Gear Bushing
62. Gasket, rear output *
63. Bolt
64. Bolt
65. Bolt
66. Bolt
67. Lockwasher
68. Nut
69. Seal, oil, felt *
Última edición por mariano salvay el Mar May 26, 2009 9:33 pm, editado 1 vez en total.
Misionero
Mensaje por Misionero » Mar May 26, 2009 9:15 pm
BUENISIMOOOO! justo lo que estaba buscando!!! :D
Si la vida fuese tan confiable com un jeep...
Re: DESPIECE REDUCTORA SPICER T18
Mensaje por Panci » Sab Jul 23, 2011 1:54 pm
Hago un pequeño aporte espero les agrade...
Mensaje por martux » Sab Jul 23, 2011 2:22 pm
y aca tienen el proceso completo, desde el desmonte del jeep... son 3 paginas con muy buena y grafica informacion
http://www.jeepbrokers.com/jeep_project ... cer_18.htm
Yogui
Mensaje por Yogui » Lun Sep 29, 2014 5:17 pm
Arranquemos por corregir que se llama Spicer 18. No T 18 que es una caja de cambios.
Atte. Yogui
YOGUI
Cazador de Gatos
Catador de Telos
